         Jaaay Newbie
           | Posted: March 08 2015 at 11:52 | IP Logged
Dave, any update on this?
           | Posted: March 08 2015 at 11:57 | IP Logged
Jaaay,
 I have purchased the Razberry daughtercard and started
 adding support for this controller. Things are
 progressing nicely and Im currently able to control
 and monitor my small collection of Z-wave devices from
 within PowerHome.
 Still have a bit to go before release but its looking
 good. Z-wave is quite a bit different from Insteon so
 its definitely an adjustment for me.
 Anyways, not sure how many different Z-wave
 controllers I'll be able to add support for since its
 a closed system but the Razberry will be the first.
         Jaaay Newbie
           | Posted: March 08 2015 at 12:20 | IP Logged
Sweet Dave!! I already have a Raspberry PI so adding a
 Razberry daughtercard should be straight forward. I like
 that the whole thing is small and will easily fit into
 my central wiring box with my insteon hub. Keep us
 updated. I have a zwave outlet I can test with. Are you
 far enough along that I can move forward with purchasing
 the Razberry?  I could be working on getting that all
 connected. Let me know.
           | Posted: March 09 2015 at 22:46 | IP Logged
Jaaay,
 Im definitely far enough along where Im confident that
 it will work well as a z-wave controller for
 PowerHome. It does require some extensive database
 changes so it will take a little while to put a
 release together. I'll be out of country for a couple
 of months as well and don't think I'll have a release
 complete before then so it will probably be 3 months
 total before I actually have something available.
 In the meantime though, it works alright using the
 internal webserver of the Razberry and you would need
 to go ahead and include all z-wave devices and get it
 working stand-alone before it would be able to be
 controlled by PowerHome.
         macromark Newbie
           | Posted: April 21 2015 at 14:37 | IP Logged
Dave (and all) - here is a shortcut that wouldn't
 require a lot of engineering. The unit handles Z-Wave
 mgmt entirely, functions as a primary controller,
 supports Z-Wave Plus features and would communicate
 back/forth with your software via ASCII or JSON
 commands: HomeSeer A2Z-Link
 http://store.homeseer.com/store/x-P1879.aspx
 So, you'd just need to write a simple JSON or ASCII
 driver to integrate it.
 FYI
 Mark Colegrove
 HomeSeer
  Edited by macromark - April 21 2015 at 14:51
           | Posted: April 22 2015 at 07:09 | IP Logged
Mark,
 Appreciate the info. I had taken a cursory look at the A2Z-Link when I was first looking for a Z-wave controller but the product wasnt yet available.
 Once I finish support for the Razberry Z-wave controller, I will definitely take another look and see about adding support for it. The ASCII/JSON interface makes the product very attractive.
 I would like to give users several options when it comes to Z-Wave so this device and open-zwave will most likely be my other options.
         nick7920 Senior Member
           | Posted: August 10 2015 at 19:56 | IP Logged
Dave any update on Z-wave ?
 My Rfid door lock is acting up and I was looking into
 Z-wave door locks - I don't have any Z-wave Hub
 (controller) . I did check the Doc's of homeseer A2Z-
 Link, seems like it can work but not cheap like
 smartThing and others. Just want to get the Hardware
 which I can use later with Powerhome.
           | Posted: August 12 2015 at 19:39 | IP Logged
Nick,
 Im back to working on the Z-wave code. Everything is
 looking pretty good so far. I can reliably read and
 write my Z-wave devices and pretty much just need to
 add the logging and triggers and should then be ready
 for a release. Its still probably a couple of months
 out though.
 The initial Z-wave controller that will be supported
 will be the Razberry Z-wave daughtercard for the
 Raspberry Pi. After that, I'll be looking potentially
 at the HomeSeer A2Z-Link controller and Open Z-wave.
         krommetje Super User
           | Posted: August 13 2015 at 02:24 | IP Logged
Awaiting while sitting on the edge of my seat....
           | Posted: August 18 2015 at 15:28 | IP Logged
I used A2Z-link and couple of Z-wave devices and control
 them thru PH -I will try to post once testing complete.
 Nick
           | Posted: November 17 2015 at 08:27 | IP Logged
Any progress yet Dave?
           | Posted: November 17 2015 at 21:12 | IP Logged
Peter,
 Z-wave development continues working on the new version. Im having very good success using the Razberry daughtercard (the first z-wave interface to supported in PowerHome) and am
 able to send/receive/trigger off of my test group of devices. I thought I was nearly done but after getting some more z-wave devices to test and add to my collection its obvious I
 need some more work. Im currently re-designing a couple of the major tables to be a more generic representation of z-wave data to handle more devices and command classes.
 Its definitely coming along and will be fully ready to go for the next version but it doesnt look like it will make it out before the end of the year with the work remaining.
           | Posted: November 19 2015 at 17:48 | IP Logged
Peter,
 I have been using Z-wave with Powerhome with makeshift
 of my own and its seems to hold okay.
 controller A2Z-link - Z-wave Controller
 devices - have power switch and Z-wave door lock.
 wrote a Bridge-plugin in java, will be happy to share
 until Dave   provides the patch to fix the plugin
 problem of powerhome.
 Z-wave devices like door lock can send lots of
 different data and status.
 Powerhome sends all Z-wave to Bridge where Bridge
 sends info to A2Z-link and any info received from A2z
 is also send back to Powerhome all thru Socket IO.
 in powerhome I am processing that info to my needs and
 using it.
 Its not very sophisticated but I can operate Z-wave
 stuff. A2Z- also has web interface and software which
 comes with it.
 Nick
           | Posted: November 20 2015 at 23:01 | IP Logged
Nick,
 Ive downloaded the protocol for the A2Z-link
 controller and it appears fairly simple. I plan to add
 support for it as well. Ive talked to Rich at Homeseer
 about the protocol but if you've discovered anything
 in actual use of the device, please feel free to pass
 on any tips or nuances as I don't actually have a
 device to test with.
 Appreciate it,
           | Posted: November 20 2015 at 23:23 | IP Logged
 its seems to works fine but with yale door lock from
 Homeseer you can add or delete user pin code. I cant
 find any way thru Ascii command. I have opened the
 Ticket for almost a month but no reply from them and I
 got busy with my work, now I will call them to check
 on it.
 let me know if you need any info or try out something
 on it.
 Nick
           | Posted: January 11 2016 at 08:10 | IP Logged
 I've got a razberry with z-wave.me daughtercard
 installed. Perhaps I can help you with testing?
 however....
 seperate installation of Beta version possible?
 machine: Win2008server running on 2.0gHz 2 Processor
 system with 4gB
  Edited by krommetje - January 11 2016 at 08:10
           | Posted: July 13 2017 at 19:38 | IP Logged
Hello Dave,
 I added few more z-wave devices and was wondering of
 Any update on Z-wave and plugin of Powerhome patch you
 had found problem and had a fix.
 Nick
         renard Groupie
           | Posted: April 11 2018 at 14:59 | IP Logged
No one has asked about Z-Wave for a while so I thought I would ask.  Dave indicated that database requirements are extensive but I am losing faith in Insteon (not PH) due to declining quality of devices (very high failure rate among my 60 or so devices), lots of false commands (lights turning on by themselves) and impossible problems with Insteon thermostats (how many times do I need to explain to my wife why the A/C cool point has been set to zero).  Insteon is a first-generation technology and no longer really fit for purpose.  I could probably start replacing failed Insteon switches with Z-Wave and have a 100% conversion in three years.  I refuse to use Insteon for sensitive applications such as door locks and watering systems due an unacceptable pattern of improper activity.  We (and PH) need Z-Wave functionality really before any other major enhancements.
 I know that Dave is working as hard as possible and had issues with Z-Wave product immaturity early in the decade but the first question about Z-Wave integration goes back to 2011.
 Just my thoughts.
 Terry
  __________________ Terry
           | Posted: April 11 2018 at 15:23 | IP Logged
Terry,
 I asked last year and still waiting (: , having said
 that I agree with you about Insteon - I have been
 replacing slowly Insteon with Z-wave and controlling
 with PH - It has its own problem but nothing like
 Insteon.
 Dave if you work with Homeseer - may be problem of
 keeping up to date with z-wave database could be
 solved and may be quicker integration with PH.
 Nick
           | Posted: April 12 2018 at 07:15 | IP Logged
Terry,
 Im nearly done with the zwave support for PowerHome (at least for an initial release...if it's anything like Insteon, it will never be "done"). The initial support will be via the Razberry daughter card for the Raspberry PI. I hope to also add support for more generic zwave interfaces using the Open Zwave libraries but will have to see if that will work out or not.
 I was also looking at adding support for the Homeseer A2Z-link controller. There was some fundamental differences in how the support would need to be handled (the Razberry is a fairly low level interface whereas the A2Z-link was a very high level interface) so I would need to design a separate set of tables. The problem now is that the A2Z-link has been discontinued. Im not certain if another device has come along to replace it or not with the same functionality but will be something that I can look into further after the release of the Razberry support.
 I share your feelings concerning Insteon reliability. It seems like Ive replaced nearly every device at least 2 times and some as many as 3 or 4. It's gotten so bad, my wife has told me she doesnt want me getting any more "crapsteon"...her words, not mine  ). Ive been pretty impressed by the zwave so far and will probably be looking to slowly migrate over time. The one thing that Insteon does have though is the variety of modules available (such as IOLinc, etc) but it does look like more and more zwave options are becoming available.
