bhlonewolf Senior Member
| Posted: January 12 2009 at 10:44 | IP Logged
Hey folks, happy new year!
Haven't been too active lately, mostly letting my system run on autopilot. I had the latest PH 1.x with a PLC running for quite some time, and it was quite solid. But, I wanted to upgrade to PH2 and a PLM, so I took the plunge about 1 or 2 weeks ago.
Overall, upgrade went smoothly, no problems, stuff working again. But, I'm starting to see some weirdness within PH. For example, lots of links not being found, or "phantom" links being found that don't make any sense. Normally, I'd chalk this up to Insteon, however, my PH 1.x w/ PLC (aside from SDM annoyances) has been flawless for many months, and nothing in the installation has changed. An example of what I mean:
So, in the picture, I've got my overhead light in my media room selected. I have two main controllers, a remotelinc, and a controlinc. Both are setup the same (as you can tell in the picture). Today I log in, and see this. It's almost like it misread one of the links (group 4 of the CL - MEDIA ROOM ID), and then put it under "unknown" at the top. However, group 4 of the controlinc still works fine, so not sure what the issue is.
Any suggestions? And happy new year!
