| Posted: December 13 2008 at 15:33 | IP Logged
All,
PowerHome version 2.1b is now available on the download page. Standard upgrade procedure including a database upgrade.
Ive still got to update the Whatsnew and Upgrade pages but it's ready to download.
Below is a quick list of changes from 2.1a.
Changed ph_insteonwithret function to allow for sending group cleanup commands. Add 1000 to the cmd1 parameter to force the function to send a group cleanup command rather than a direct command.
Added New Insteon triggers. Insteon NAK and Insteon Timeout.
Renamed Insteon Direct In (ACK) trigger to Insteon ACK with options for Direct and Group Cleanup ACK in and Direct and Group Clenup ACK out.
Reworked all existing Insteon triggers (except Insteon Device Chg Trigger) to allow for ANY on the ID and ANY on the commands. Insteon triggers now have flexibility similar to the new UPB triggers (NOTE: This change has affected the values in the [TEMP] variables associated with these triggers).
Rewrote the Execution Queue module for much greater efficiency. Eliminates slowdowns while waiting for controllers.
Changed update properties on Timed Events Maintenance to "Update" from "Delete then Insert" to help minimize problems with Timed Events disappearing when mass updating ID's.
Changes made to webserver shutdown code to hopefully fix problem where a socket will remain open preventing the webserver from restarting.
Added socket connection monitoring to Elk M1 Gold ethernet (M1XEP) controller. If a socket disconnect is detected, PowerHome will attempt to automatically reconnect.
Fixed bug in Control Center global variable object types where multiple objects referencing the same GV may not always be updated.
Fixed bug in ANSI and Unicode versions of Remote CC Client where objects would not be updated unless both x and y were <> 0 instead of x or y <> 0.
Fixed bug where updating a global variable via the webserver would not create an eventlog entry.
Added ability to preview and print PowerHome Explorer screens.
Added option for Insteon commands (Direct and Group Cleanup) to be sent without retries. Add 1000 to CMD1 to make use of this option.
Added option to pwrhome.ini ([SYSTEM]loadscript) to optionally load the Script Server.
Added option to pwrhome.ini ([SYSTEM]autoregister) to optionally automatically register activex controls at startup.
Added option to pwrhome.ini ([SYSTEM]confirmshutdowndefault) to allow user to select the default timeout action if Confirm Shutdown is true.
New Functions:
Changed Functions:
ph_insteonwithret
Removed Functions:
PWRHOME.INI Changes:
[System]
LoadScript=YES
AutoRegister=YES
ConfirmShutdownDefault=NO
option1=273
option2=571
option3=966
option4=351
option5=632
Database Changes:
dropdowns,all_id,all_id_data,all_value_data
Let me know of any problems.
