| Posted: December 16 2008 at 09:09 | IP Logged
I utilized the new Wizard to set up my Control Center
buttons and then tuned the results to better fit my
needs.
The one thing I would like, but couldn't discover a
means to create was to have some of the critical on/off
buttons actually reflect the state of the controlled
device.
That is if a device is "on" is it possible to reflect
that in the button appearance by appropriate entries in
the CtrlPanel configuration table?
| Posted: December 16 2008 at 13:29 | IP Logged
Not automatically as of now. You could set up some triggers to update CC objects.
| Posted: December 16 2008 at 15:43 | IP Logged
Humm! Interesting and doable idea. Thanks for your (as
always) awesome insight!
nadler Super User
| Posted: December 18 2008 at 22:04 | IP Logged
As in everything PH you can do this in a number of
different ways and probably everyone on this board does
what you would like to do, but each person does it
differently.
You could keep the status of each device in a global
variable. PH2 and above added the action global
variable, static global variable and global variable
button types. You would create a box on a CC screen of
one of those global variable types and point it to a
particular global variable from the drop down menu.
Every time the global variable changes the CC screen
automatically changes the contents of that box. I use
it to let me know if my speakers are on or off in each
room. I place and On or Off in the global variable for
that particular set of speakers and then their status is
reflected as either On or Off in the box. The advantage
to a global variable box or button is that you can use
the same box or button on multiple CC screens and point
them to the same global variable and all the screens
change at same time the global variable changes.
If you want to change the color of the box or button to
reflect the on or off status you can make an action text
box or button and use a raw formula for each button. In
the example below I use one button to toggle an Insteon
light on or off depending on its present state. If it
is on the button turns green. If it is off the button
turns yellow. The disadvantage here is that the formula
for each button for each different device is different
and while it accurately reflects the status of the
insteon device when pressed, if the light switch is
pressed the screen doesn't change and the screen is no
longer accurate. For that you couple this approach with
a trigger for the PLM which fires a macro which changes
the status of all buttons on all screens. Depending on
the number of insteon devices you and how many CC
screens you have, that macro gets very long
Here is the raw formula to toggle an insteon light's
status and to change the color of the button or box
controlling that light:
The name of the light is MASTERBEDROOM.
The name of the button on the CC Tab is W1
if (ph_getinsteonstat(
"MASTERBEDROOM")=1,ph_insteon("MASTERBEDROOM",18,0)+
ph_setccobjbcolor("CC_TAB_NAME","W1",65280),ph_insteon("
MASTERBEDROOM",20,0)+ph_setccobjbcolor("CC_TAB_NAME","W1
",65535))+ ph_wcrefresh()
When the button is pressed if the MASTERBEDROOM light is
on it turns it off and paints the box yellow. If the
MASTERBEDROOM light is off the button press turns it on
and paints the box green.
I use the ph_wcrefresh() command to refresh this
particular CC screen because I use it on my iTouch and
it refreshes the current page in the Web center thus
accurately reflecting the color of the button.
| Posted: December 18 2008 at 22:48 | IP Logged
nadler - very nice response and good tutorial!
It sure helps when there is an example (now if we could
just convince Dave and the Manual writers how useful
even a single actual example is vs a generic function
description. . . if nothing else it helps show where
quotes are needed, or not!).
I leave for Mexico tomorrow, but look forward to
utilizing your clear and thoughtful response as soon as
I return.
As they say in Spain, "Cool Beans!"
