mustangcoupe Super User
| Posted: September 16 2008 at 18:33 | IP Logged
So I used upstart to program my devices. now I exported the file and went to ph to import and had a problem when I went to setup my controller..... Where do I find the device ID for my controller? I am a bit lost here? I dont see it in upstart. My pim is not a device in my network. (I tried to add it and it does not find it) maybe I am doing it wrong.
HA newbie
PowerHome - UPB - ELK
| Posted: September 16 2008 at 19:10 | IP Logged
Todd,
For the PIM, just choose whatever unit ID you like that isnt currently in use by a device. In my setup, I just use the max value of 250. When PH starts and connects to the PIM, it will program it with the value you select.
| Posted: September 16 2008 at 19:33 | IP Logged
Thanks Dave I was confused a bit. I did just choose 250 because it was out of the way before you responded... :)
HA newbie
| Posted: September 18 2008 at 08:23 | IP Logged
thanks dave upb works great!
HA newbie
