jckinneman Newbie
| Posted: October 07 2008 at 13:25 | IP Logged
I have updated to version 2 beta and everything is working fine. I have some records that are listed as "flagged delete" but they never go away. I checked the documentation and didn't find anything on how to get rid of these records.
Is there a process to clean these out?
Jim K.
| Posted: October 07 2008 at 14:04 | IP Logged
If you only want to clean up the PH2 database, drag the link record to the "Remove" button and drop. If these are link records which also exist in a device and you want to delete the link records from the device, check to see if the device is marked Disabled or the Comm Failed column is highlighted for that device.
Also be sure the Enable Pending is checked if deleting from a device.
Edited by grif091 - October 07 2008 at 14:05
jckinneman Newbie
| Posted: October 07 2008 at 14:36 | IP Logged
That was easy! Thanks much.
