| Posted: August 27 2008 at 08:44 | IP Logged
Just swapped out a PLC for a PLM several weeks ago and am finding that I can not Auto Discover devices using that feature of PowerHome.
Nothing ever shows up in the discovery window, no matter what I do.
Is there a trick with the PLM, or doesn't it link in this mode of operation?
| Posted: August 28 2008 at 16:11 | IP Logged
Did you go through this procedure??
http://www.myx10.com/forum/forum_posts.asp?TID=1751&KW=plm
| Posted: August 29 2008 at 10:15 | IP Logged
Yes. I did that when I switched over from a PLC to the PLM, and successfully copied all my links which seemed to then all work except for several things. . .
1. I do not seem to be able to auto detect Insteon devices with the PLM.
2. When I drag/drop devices into the Controller/Responder window of the Insteon Explorer Links Tab and Save, etc. they do not seem to "take". Occasionally they work but for the most part I have to go around to the devices and manually link them to each other to make things work.
I've got a new PLM coming today from SmartHome. I'm hoping I just have a flaky one and that the new one will fix the many strange issues I'm having.
