traviskleckner Senior Member
| Posted: September 05 2008 at 14:49 | IP Logged
What's the best way to get analog or contact closure
type data to PH? (Say for example a relay connected the
door bell to tell PH when the door bell button is
pressed? Or respond to the contact closure on an alarm
system?)
Seems to me that using Insteon is both expensive and
round about way to do it (not to mention adding one more
delay step.)
Are there USB/Serial devices out there that work with
PH? Does anyone have something they are really fond of?
| Posted: September 05 2008 at 17:44 | IP Logged
For contact closures, I would now use a DS10A (X10 RF Door/Window Sensor) and a W800RF32A.
I actually use an old, X10 table-top controller right now for my doorbell. I hacked the contacts across one of the On buttons.
jeffw_00 Super User
| Posted: September 07 2008 at 20:01 | IP Logged
Can always use an X-10 Powerflash module. i have one hooked to my doorbell, and chime modules around the house. Powerhome also picks up on the signal and uses it to flash insteon lights a couple of places.
Edited by jeffw_00 - September 07 2008 at 20:02
| Posted: September 07 2008 at 20:14 | IP Logged
Good call. I never had one, but that is simpler.
| Posted: September 10 2008 at 10:04 | IP Logged
Thanks. I'll look into that.
I was actually hoping for a solution that could sidestep
the whole X-10 or Insteon all together. Seems like
there are enough devices out there that would do that.
Oh well.
mustangcoupe Super User
| Posted: September 10 2008 at 12:43 | IP Logged
Well, it really depends on the price you want to pay... there are other options. If an ELK M1Gold isn't out of the question then Id say use one of them and monitor the "zone" status with PH
HA newbie
PowerHome - UPB - ELK
jbbtex Senior Member
| Posted: September 10 2008 at 13:26 | IP Logged
The x10rf stuff with a W800RF32A is rock solid. I use the DS10A for everything; garage door sense, closet door sense, rain gauge. Add some motion sensors for walk-in closets.
__________________ Brady
