funbobbybaby69 Groupie
| Posted: July 17 2008 at 09:31 | IP Logged
Does anyone know if you can setup the IRLink to send a "fake" insteon address so PH can pick it up and transfer it to an X10 address?
Rob
| Posted: July 17 2008 at 09:33 | IP Logged
Wow... what a dumbass i am.... No need for PH in that case....
Setting Up X10 Addresses
1) Press & hold the Set button on IRLinc for about 5 seconds, then release
Blue LED will turn off
2) Send the desired X10 address 3 times
Blue LED will begin blinking
3) Press the button on your remote you wish to learn (holding the remote 6-12 inches from the IRLinc IR Receiver)
Blue LED will return to steady on
4) To test, press the button learned on your remote several times. It should turn your X10 products on and off (press & hold to dim or brighten).
Note: IRLinc will only send either INSTEON or X10 for a given programmed IR code. Please refer to the troubleshooting guide for more information.
| Posted: July 17 2008 at 15:13 | IP Logged
In PH I trigger off an Insteon address which fires my X10 stuff and the reverse.
