Bracken Newbie
| Posted: May 01 2008 at 12:36 | IP Logged
I am just getting started into an automation system. I will be using PH, but i am having a hard time understanding which controller i need. I bought some x10 stuff and it came with HC60RX (serial) controller, they said it was compatible with cm11a. i am unable to get it work though, even with there own software.
I was thinking about using a USB x10 controller instead, but i am unsure which ones do what and are compatible with PH. I am not impressed with the x10 tech and will most likely want to upgrade to the insteon tech soon. I looked into the Powerlinc but i don't understand if theres one that does both or not.
I don't need one with memory i intend on having a dedicated computer to run it all the time.
Any suggestion would be great appreciated. thanks.
Edited by Bracken - May 01 2008 at 15:56
