        | JaredM Newbie
          First time PH user... Looks cool. I can't get past one error though and I'm hoping someone can help. I've done a lot of searching through the forums and haven't found a solution yet.
           | Posted: November 04 2007 at 14:41 | IP Logged |   |
 I see the following consistently: "SmartHome Device Manager ISRESPONDING command failed for Insteon PLC INSTEON CONTROLLER. Attempting to restart controller..."
 I've tried starting SDM3.EXE from within \Program Files\PowerHome\SmartHome\Device Manager\. I've tried switching between 235 and 308 using the included batch file. I've tried uninstalling\reinstalling.
 SDM seems to work on its own b/c when I run the exe manually, click on the icon, type 'DM', then type 'isresponding' it says PLC:isresponding:True.
 Other apps that use SDM, like Device Controller, work fine.
 I'm running PH 1.03.4.12 on Vista.
 Any suggestions?
        | Back to Top |     |
        | dhoward Admin Group
          Jared,
           | Posted: November 04 2007 at 15:51 | IP Logged |   |
 Welcome to PowerHome!!
 The fact that you got PowerHome to install on Vista is interesting since most users have been unsuccessful.  I know of only one other user who was successful in getting this to work on Vista and it involved having to first get the SDM properly configured using HouseLinc.
 Based upon this one users experience and the fact that other programs are able to work with the SDM, Im confident that we can get PowerHome working as well.  Would it be possible for me to connect into your machine using VNC and try to work with you on getting this to work?  If so, send me an email and we'll work out the details.
        | JaredM Newbie
          Great! I'll send you my contact info.
           | Posted: November 04 2007 at 19:06 | IP Logged |   |
        | Back to Top |     |
        | dhoward Admin Group
          Jared,
           | Posted: November 04 2007 at 22:43 | IP Logged |   |
 Excellent news!  I got your email and hopefully we'll get this fixed.  Also, you may want to check towards the end of this thread  http://www.power-home.com/forum/forum_posts.asp?TID=970&TPN= 3.  Brian (bhlonewolf) has made some excellent progress and was successful in getting the SDM and PowerHome working on Vista.
        | JaredM Newbie
          I wouldn't believe it if I didn't see it, but turning UAC ON actually fixed my problem. Dave VNC'ed into my machine and both the ISRESPONDING error mentioned above and the "script server: -2" error I was also seeing went away when I turned it back on.
           | Posted: November 05 2007 at 23:11 | IP Logged |   |
 I had disabled it a while back.
 Dave, to confirm the theory I turned UAC off, rebooted and the problems came back. Turned it back on, rebooted and then went away again.
 I'm not running in compatability mode.
        | Back to Top |     |
        | cmhardwick Senior Member
          ALL TOGETHER NOW ....
           | Posted: November 06 2007 at 08:43 | IP Logged |   |
 WE HATE UAC hehehe
 I haven't switched to Vista and stories like this concerning UAC are one of the main reasons I haven't, not to mention just various incompatibility issues.
 Glad you got it working. Amazing that turning it ON fixed it since most people, to get things to work, have to turn it off.
 Cicero, Enjoying automation!
        | bhlonewolf Senior Member
          Well, like I said in another post, I don't think it's UAC -- I think UAC is providing transparency to the problem.
           | Posted: November 06 2007 at 09:05 | IP Logged |   |
        | Back to Top |     |
        | crisx Groupie
          JaredM,
           | Posted: November 06 2007 at 11:31 | IP Logged |   |
 Just out of curiosity, which flavor of VNC are you using on Vista?  I was about to pick one to install, but it looks like a lot of them are having problems with vista.
 Thanks, Cris
        | Back to Top |     |
        | JaredM Newbie
          I just used the one Dave links to at the bottom of PH homepage. He was controlling my machine and it seemed to work OK except for being very laggy -- like 5s.
           | Posted: November 07 2007 at 01:48 | IP Logged |   |
        | Back to Top |     |
        | psychoholica Newbie
          Well, I used the HKLM to HKCU registry fix posted a couple days ago by bhlonewolf which got me past the -2 error with Vista but now I have this problem.
           | Posted: November 10 2007 at 15:02 | IP Logged |   |
 The DM sees my device on USB4, if I unplug it and plug it back in the DM logs that it detected the Smarthome USB by echoing:
 (usbarrival=4287,4,1024,SmartHome,SmartHome PowerLinc USB E,)
 However when I add it as a Controller I start getting the "SmarthHome Device manager ISRESPONDING command failed for Insteon PLC smarthomeUSB. Attempting to restart controller...
 Any idea? 1 step closer!
        | Back to Top |     |
        | BeachBum Super User
          When I had this problem it was the ISRESPONDING in the SDM windows responds false. I then type SENDHARDRESET and then reload CORE APPS. Good luck...
           | Posted: November 10 2007 at 15:15 | IP Logged |   |
        | Back to Top |     |
        | psychoholica Newbie
          Loaded Powerhome, started the device manager and typed SENDHARDRESET, it seemed to work.  Reloaded PowerHome, still having the ISRESPONDING error.
           | Posted: November 10 2007 at 16:01 | IP Logged |   |
        | Back to Top |     |
        | dhoward Admin Group
          Psychoholica,
           | Posted: November 11 2007 at 13:48 | IP Logged |   |
 Have you tried with UAC On?  This is the exact problems we were having with Jared's Vista install and the problem went away once we turned UAC on.
 Let me know,
        | psychoholica Newbie
          Woo Hoo,
           | Posted: November 12 2007 at 02:53 | IP Logged |   |
 |  up and running with Vista.  but UAC has to be one...ew!  Hopefully a fix for this is easy, the UAC right now is a terrible feature in Vista.
 Thanks, now to finally test this stuff out!
        | Back to Top |     |
        | jeremybe Newbie
          Where exactly do you turn UAC on? I'm getting the same exact problem, I ran the registry fix, did a reinstall of Powerhome and restored my database, Powerhome comes right up, the SDm see's my device, but Powerhome gives me "SmarthHome Device manager ISRESPONDING command failed for Insteon PLC smarthomeUSB. Attempting to restart controller"
           | Posted: November 16 2007 at 12:31 | IP Logged |   |
 Anyhelp would be appreciated!
        | Back to Top |     |
        | JaredM Newbie
          Jeremy, try
           | Posted: November 17 2007 at 02:12 | IP Logged |   |
 |  Start
 Control Panel
 Classic View
 User Accounts
 You'll see an option to Turn User Account Control on or off.
        | Back to Top |     |
        | jeremybe Newbie
          Thats what I thought Still no luck for me ... Keep getting the "ISRESPONDING" error message.. Any other ideas?
           | Posted: November 17 2007 at 07:54 | IP Logged |   |
        | Back to Top |     |
        | JaredM Newbie
          Just to be sure, did you reboot after turning UAC on? Also, have you tried some other stuff on this thread (hard reset, reload core apps)?
           | Posted: November 17 2007 at 14:12 | IP Logged |   |
        | Back to Top |     |
        | jeremybe Newbie
          Yup..
           | Posted: November 18 2007 at 11:59 | IP Logged |   |
 |  I'm running with UAC on now, I've applied the regstry fix, I tried running in compatability mode and I've tried running as an administrator - I've also tried a hard reset and a reload of the apps - but I'm still getting the ISRESPONDING message..
        | Back to Top |     |
        | BeachBum Super User
          Curious, does ISRESPONDING work from SDM without loading PH?
           | Posted: November 18 2007 at 12:06 | IP Logged |   |
 Edited by BeachBum - November 18 2007 at 12:21
        | Back to Top |     |
