AllanMar Groupie
| Posted: June 07 2007 at 20:41 | IP Logged
ID: IR. USB-UIRT IR Controller.
Firmware: 5.9
Protocol Supported: 1.1
Firmware Date: 2004-3-26
API Version: 256
IR Codes appear in the event log, i get an error about a timeout whenever i attempt to auto-learn or record codes though.
Any ideas?
AllanMar Groupie
| Posted: September 30 2007 at 11:53 | IP Logged
I have some plans for the USB-UIRT, and this problem is still there.
Anyone?
AllanMar Groupie
| Posted: September 30 2007 at 13:13 | IP Logged
As an update:
I have used the USB-UIRT Learner Utility to learn some codes.
When i enter them into powerhome, everything appears fine. However when it transmitts them, they do not work. The led dosnt stay lit as long as when the Leaner utility transmits them (which does work)
-Allan
sharby Groupie
| Posted: September 30 2007 at 17:23 | IP Logged
I have/had the same exact issue. I haven't had a chance to report it to Dave. If continuously keep trying to AUTO-LEARN until it finally works. Try holding the remote "right on" the sensor until it turns red.
-=*Sharby*=-
ginigma Senior Member
| Posted: September 30 2007 at 23:27 | IP Logged
I have a USB-UIRT that works fine with PowerHome. I don't think I used any "learn" settings. I just looked in the event log after I pressed buttons on my remote to get the codes, then pasted them in where appropriate.
I love the UIRT because it picks up signals from my Harmony 880 even when it's aimed down at the carpeting.
AllanMar Groupie
| Posted: October 01 2007 at 19:15 | IP Logged
I seem to be able to get it to learn most of the time now. It learns the correct codes, however it fails to transmit them correctly.
Any ideas? Dave?
| Posted: October 03 2007 at 13:37 | IP Logged
Allan,
Can you post some examples of the learned codes? I might be able to see what the problem is.
AllanMar Groupie
| Posted: October 10 2007 at 15:23 | IP Logged
Incoming Code: 170000AD00CA
OutGoing:
<uirtstruct>F4205EF1511111122221154D511000000000000000 00000000000<repeat>3
I have tried UIRTRAW/Proto aswel.
| Posted: October 15 2007 at 10:38 | IP Logged
Allan,
UIRTSTRUCT is probably not the best mode. This mode stores the least amount of information about the IR code is definately not as reliable as the others.
For testing purposes, I would set the record type to PRONTO and restart or reinit PowerHome. The Incoming code you posted looks OK and the UIRTSTRUCT code doesnt look out of the ordinary, but posting a Pronto code would give more information. Also, is it a particular remote that is having problems or is it a problem with every remote that you try to learn. One last thing as well, post what your settings for the USB-Uirt are. Several of the settings are very critical for the proper learning of IR commands.
Let me know,
