        | Kremlar Newbie
          Running PowerHome v1.03.4.11
           | Posted: August 01 2007 at 17:06 | IP Logged |   |
 |  DB version 1.03.9.5
 Just noticed that I have double entries in my Insteon Device Type list.
 Is this a problem?  Is it a known issue?
 Edited by Kremlar - August 01 2007 at 17:07
        | Back to Top |     |
        | smarty Super User
          Pretty sure that is by design.  You might have a switch connected to a load, and another switch acting as a "control" only.  To cover all possible situations, you need duplicates for all device types.
           | Posted: August 01 2007 at 17:39 | IP Logged |   |
 Edited by smarty - August 01 2007 at 17:42
        | Back to Top |     |
        | Kremlar Newbie
          Thanks for the reply.
           | Posted: August 01 2007 at 17:50 | IP Logged |   |
 I think I need clarification... I do have some devices controlling a load, and others for control only - but I don't understand why I would need to choose different Device Types for one or the other.
 Could you elaborate?
        | Back to Top |     |
        | ginigma Senior Member
          Check this thread:
           | Posted: August 01 2007 at 21:28 | IP Logged |   |
 |  http://www.power-home.com/forum/forum_posts.asp?TID=1051&KW= control+only
        | Kremlar Newbie
          Thanks for the link!
           | Posted: August 01 2007 at 21:52 | IP Logged |   |
 Just to clarify, my database not only has (Control Only) devices, but exact duplicates of everything.
 For example, I have:
 2476D - SwitchLinc Dimmer 600 watt
 2476D - SwitchLinc Dimmer 600 watt (Control Only)
 Is this normal?
        | Back to Top |     |
        | smarty Super User
          Hmmm....
           | Posted: August 01 2007 at 22:20 | IP Logged |   |
 I DON'T have duplicates like that.
 Sorry to be of no help.  Maybe Dave will chime in soon.
        | Back to Top |     |
        | bhlonewolf Senior Member
          I've got the same thing :)
           | Posted: August 01 2007 at 22:25 | IP Logged |   |
        | Back to Top |     |
          I think I had the same thing after upgrading.  I just deleted the dupes and haven't had any issues since.
           | Posted: August 01 2007 at 22:55 | IP Logged |   |
        | smarty Super User
          Weired....
           | Posted: August 02 2007 at 07:46 | IP Logged |   |
 |  I check my work machine this morning and it HAS the duplicates.  Something's not quite right....
        | Back to Top |     |
        | TonyNo Moderator Group
          Dupes here, too, but not for every device.
           | Posted: August 02 2007 at 08:25 | IP Logged |   |
 Edited by TonyNo - August 02 2007 at 08:26
        | Kremlar Newbie
          Is it OK to simply go in and delete them?
           | Posted: August 02 2007 at 08:52 | IP Logged |   |
        | Back to Top |     |
        | BeachBum Super User
          Dupes here, too but I checked the last version and they had them too.
           | Posted: August 02 2007 at 11:14 | IP Logged |   |
 Edited by BeachBum - August 02 2007 at 11:15
        | Back to Top |     |
        | dhoward Admin Group
          It appears that in either the .11 or .10 database upgrade utility that I inadvertantly created duplicate entries while trying to insure that the Insteon types table had all of the latest Insteon devices.
           | Posted: August 04 2007 at 21:15 | IP Logged |   |
 As such, the dupes don't hurt anything and can be safely deleted.  Open the Insteon Explorer and click on the "Types" tab.  Delete the duplicate entries but make sure and delete the duplicate entry that is further down the list.  They'll be sorted to appear right next to each other but if row 1 and row 2 are identical, delete row 2.  Press the Save/Refresh button and then go to the "Devices" tab.  Click on the Save/Refresh button and make sure that all of your Insteon devices still show a valid Insteon Type.  Fix any that dont and press Save/Refresh.
