        | Kremlar Newbie
          I created some links on a device through another piece of software, and now I want PowerHome to update it's database.  I thought I could simply go to the Links tab, select the device, and do a Reverify, but it doesn't seem to be doing anything when I click that button and Save.
           | Posted: July 09 2007 at 08:08 | IP Logged |   |
 What am I doing wrong?
        | Back to Top |     |
        | TonyNo Moderator Group
          I think you would want to enable link spidering for that.
           | Posted: July 09 2007 at 12:42 | IP Logged |   |
        | Kremlar Newbie
          OK...
           | Posted: July 09 2007 at 18:09 | IP Logged |   |
 So, I check off "Allow Link Spidering", I click on the device in the Links tab, I hit Reverify, and click Yes.
 Nothing seems to happen...
 This seems like it should be a very basic function, I must be doing something wrong..
 Any other ideas?
        | Back to Top |     |
          Check at the end of this thread for more info from Dave...
           | Posted: July 09 2007 at 19:13 | IP Logged |   |
 http://www.power-home.com/forum/forum_posts.asp?TID=937
 Start reading where you see...
| Quote:
       | When using "Allow Link Spidering" |  |  |
 Edited by TonyNo - July 09 2007 at 19:14
        | Kremlar Newbie
          Thanks...
           | Posted: July 10 2007 at 06:18 | IP Logged |   |
        | Back to Top |     |
        | dhoward Admin Group
          Actually, to re-scan a device for new links, open the Insteon Explorer and go to the "Devices" tab.  Place a check in the "Scan DB" column for the device whose database you wish to rescan and press the "Save / Refresh" button.
           | Posted: July 10 2007 at 11:06 | IP Logged |   |
 Of course, "Poll Interval" must be greater than 0 (usually 10).  If "Status Scan" and "Link Scan" are checked, PowerHome should have picked up the database changes automatically and rescanned the device for you (it may have taken it a few minutes if you have alot of devices).
