         fasttimes Groupie
           | Posted: October 14 2006 at 02:46 | IP Logged
How can you setup a Keypad linc, or any switch for that matter to turn on one device, then turn off others?
 e.g.  Button B on a keypad link should
 Turn off the lights over the stairs
 Dim the overhead lighs in the living room
 Turn on the relay connected to the stero
 etc.
 I know this can be done with a macro, but isnt there a way to do this soley with links?
         crisx Groupie
           | Posted: October 14 2006 at 11:19 | IP Logged
Fasttimes,
 As far as I know, this is not possible without the use of PowerHome or other software.  I agree this would be useful.  If someday in the future Smarthome changes the firmware to allow a button to trigger other button's groups, this would be possible using non-toggle buttons, but for now, I think you are stuck using PowerHome to 'do it'.
           | Posted: October 17 2006 at 17:19 | IP Logged
Fasttimes,
 If the device you're wanting to turn off is a dimmable light, then just set the level to 0.  My understanding is that Insteon considers level 0 to be the same as OFF anyways.
 If the desired device is not dimmable, then I think that you would have to use Cris' suggestions.  I havent tried it, but it would be interesting to see what would happen with setting an appliance or relay module to a level of 0 from within a group.  Might get lucky.
         mccljs Newbie
           | Posted: January 05 2007 at 17:19 | IP Logged
I have tried setting the level of a SwitchLinc V2 Relay to 0 and it turns off and to 255 and it turns on both from a KeypadLinc button and a PLC group.
