ivulpe Newbie
Posted: February 02 2012 at 11:56 | IP Logged
I've been playing around with the email plug-in for a couple of days now and I can't make it work so ... it's time to ask for help. For some reason I'm getting a "return code -3" and I have no idea what that means.
Iulian
__________________ I
krommetje Super User
Posted: February 02 2012 at 13:00 | IP Logged
Haven't tried the plug-in yet so can't help YET, Where can I DL. the plug-in and I'll try it....
ivulpe Newbie
Posted: February 02 2012 at 13:25 | IP Logged
The plugin comes with powerhome. There are two files in the plugin folder and you can find instructions here:
http://www.power-home.info/wiki/index.php?title=PowerHome_Ge neric_Email_Control_Tutorial
Posted: February 02 2012 at 15:16 | IP Logged
ivulpe,
Which version of PH are you using? There is probably an issue with PowerBuilder versions since this particular plugin was written using an older version of PowerBuilder.
Also, I will be working on a new POP3/IMAP plugin soon and am also planning to update the current email plugin (which uses MAPI) to one which will be extended MAPI compliant.
Let me know what you're trying to do with the current email plugin so I can make sure I have you covered in the newer versions.
ivulpe Newbie
Posted: February 02 2012 at 15:42 | IP Logged
Thanks for your quick reply Dave. I'm running 214 on XP SP3. I think you are right, the PowerBuilder seems to be the cause.
No worries, I was just playing with this plugin to see if i can control my lights but I can wait for the upgarade if there's no fix now.
Iulian
Posted: February 04 2012 at 10:49 | IP Logged
Sorry, can't help, I've got an error too...
Error -2 says the log
