        | tbeckman Senior Member
          How come Device Status is not always updated... I can see it in my logs when I turn a light on and off, so I know the signals are getting through... but why doesn't the Devis Status windows change to match?  Thanks.
           | Posted: January 02 2008 at 03:23 | IP Logged |   |
 Edited by tbeckman - January 02 2008 at 03:23
        | Back to Top |     |
        | TonyNo Moderator Group
          Which device types are you referring to?
           | Posted: January 02 2008 at 07:16 | IP Logged |   |
          Sorry, I am using insteon... PLC 2414s AND their switchlinc switches.  Thanks.
           | Posted: January 02 2008 at 11:57 | IP Logged |   |
        | Back to Top |     |
          Check to make sure that you don't have those set up as Control Only. This is shown as "(Control)" after the description in the Insteon Types screen.
           | Posted: January 02 2008 at 12:34 | IP Logged |   |
          I checked and it doesn't appear to be set for control only.
           | Posted: January 02 2008 at 13:43 | IP Logged |   |
        | Back to Top |     |
          Okay, that's strange.
           | Posted: January 02 2008 at 20:42 | IP Logged |   |
 Maybe someone else has ideas.
        | cmhardwick Senior Member
          Are they NEVER updating or just sometimes? Any specific switches or all? Are all the switches linked as controllers to the PLC?
           | Posted: January 03 2008 at 08:22 | IP Logged |   |
 Cicero, Enjoying automation!
          They will sometimes be correct and sometimes not.  I have one switch that is close to me (which is why I use it for testing)that it will almost always show status when I turn it on... but not off.  It is so random.  All switches have the PLC as a controller.
           | Posted: January 03 2008 at 11:43 | IP Logged |   |
        | Back to Top |     |
          Ok, status changes when going from off to on, but not reverse. What's that switch controlling, Florescent fixture?
           | Posted: January 03 2008 at 13:01 | IP Logged |   |
          No. just a regular incandesent light.  no flour. in my house.
           | Posted: January 03 2008 at 13:32 | IP Logged |   |
        | Back to Top |     |
