scottmi1 Groupie
Posted: March 06 2009 at 13:09 | IP Logged
Having a problem getting the datetime function to work in my macro.
This formula works:
date(ph_regexdiff("<date>","</date>","[LOCAL1]",1,0))
Source value is "03/06/09" and returned value is "03/06/2009"
And this formula works:
time(ph_regexdiff("<time>","</time>","[LOCAL1]",1,0))
Source value is "12:10 PM" and returned value is "12:50:00"
But this formula doesn't (it evaluates to !):
datetime(ph_regexdiff("<date>","</date>","[LOCAL1]",1,0),ph_regexdiff("<time>","</time>","[LOCAL1]",1,0))
So I tried this and it doesn't work either:
datetime("03/06/09","12:10 PM")
Any ideas what I'm doing wrong?
Mike..
Posted: March 06 2009 at 13:39 | IP Logged
Try separating the 2 with a + instead of a ,
datetime(ph_regexdiff("<date>","</date>","[LOCAL1]",1,0) + ph_regexdiff("<time>","</time>","[LOCAL1]",1,0))
Edited by BeachBum - March 06 2009 at 13:41
jbbtex Senior Member
Posted: March 06 2009 at 13:42 | IP Logged
try it like this:
datetime("03/06/09, 12:10pm")
__________________ Brady
scottmi1 Groupie
Posted: March 06 2009 at 14:05 | IP Logged
Brady - your correction worked and gave me the clue I needed to fix my original formula.
Pete - I replaced the comma with a "+" and while I didn't get an error, the returned value was blank. I then figured out I needed both. Here's the formula that works:
datetime(ph_regexdiff("<date>","</date>","[LOCAL1]",1,0) + "," + ph_regexdiff("<time>","</time>","[LOCAL1]",1,0))
Thanks for the quick replies!
Mike..
