Plano_Mike Newbie
Posted: August 19 2006 at 14:17 | IP Logged
Dave--
I am now up nearly 50 Insteon devices in my house. PH has been stable and working pretty well. However, I have replaced a few devices and have noticed that over time a numbe of the devices in the PH "By Controller" screen were not in Verified status. I was going to try to get my devices into my Elk this weekend and get a second controller going with it, so I figured I would try to clean up my database first.
I tried clear the database and have PH rescan everyting using the procedure you described in LazyMans May 22 post (see http://www.power-home.com/forum/forum_posts.asp?TID=731).
When I do "Scan All Device Database" step from a right click on the "Units" screen, nothing much happens. I have tried several times now, and only a single link has appeared in the "By Controller" screen. I have the 1.03.4.7-4 patch (I may try re-applying). All of my devices do appear in the "Units" screen.
Any suggestions?
Mike
__________________ Mike
Posted: August 20 2006 at 20:21 | IP Logged
Mike,
You'll want to watch the SDM3 log as PowerHome is verifying the links. If you see alot of eventraw=3 messages followed by a NAK message or SRIR failed, then you may have a communication problem. The first thing I would try however is to make sure that the SDM has all the latest, correct programming. From the PowerHome Explorer in the Insteon Devices screen, right click and open the Insteon DM Control. Press the "Download Core Application" button. When done, do the "Clear PLC Database" followed by "Add ID's to PLC". This should clear up any problems related to the PLC not communicating properly with your Insteon network.
Let me know how it goes,
Plano_Mike Newbie
Posted: August 20 2006 at 22:11 | IP Logged
Dave--
I did as you describe and it does not seem to have solved anything.
Here is what my DM log shows:
8/20/2006 9:10:29 PM:nakmsg
ui:sendinsteonraw=00 00 00 01 86 F8 05 28 0F
uifinished:sendinsteonraw=00 00 00 01 86 F8 05 28 0F
si:00 00 00 01 86 F8 05 28 0F
PLC:sendinsteonraw=True
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=03
PLC:eventraw=05
8/20/2006 9:10:34 PM:nakmsg
Posted: August 21 2006 at 00:59 | IP Logged
Mike,
Definately looks like a classic communication issue. What the log is showing is PowerHome trying to peek a memory loction in device 01.86.F8. I would look up this device in your Insteon devices list and try to determine what is wrong with this device.
The bad news is that the current version of PowerHome will essentially "hang" on trying to communicate with this one device and no other background processing (foreground processing will still take place such as on/off commands from PowerHome) will happen until the problem with this device is cleared.
Let me know what you find out.
Plano_Mike Newbie
Posted: August 21 2006 at 10:12 | IP Logged
Dave--
I had an Incon LampLink on the system which I was not using for the moment. Plugged it in, and all seems to be well at this point.
Many thanks as always!
Mike
ginigma Senior Member
Posted: August 21 2006 at 17:42 | IP Logged
Ouch!
I've noticed similar comm issues where the device that's hanging is a Switchinc, which appears to be operating fine.
Will this "hang" issue be resolved in the next beta? Any timeframe?
Paul_PDX Newbie
Posted: August 28 2006 at 16:14 | IP Logged
I ran into this same situation last week -- I had received a dozen new appliance lincs and I built sql to add them all to powerhome. I only had one of them actually installed anywhere. The background scanning eventually got stuck on the one of them and power-home stayed useless for the next day until I noticed none of my triggers and macros had been occurring. I thought I could just uncheck "previous exclude" and they would be ignored but that didn't seem to do the trick so I deleted all of the unused ids.
Posted: August 29 2006 at 23:33 | IP Logged
This should be fixed in the next version. Communication stats are now stored and when a device is deemed unreachable, it will no longer cause the system to hang.
