AllanMar Groupie
| Posted: May 04 2007 at 12:44 | IP Logged
This is more of an Insteon question than ph.
Is it possible to have the lamplinc report it's status when i turn it on by the switch on the lamp itself?
I can't seem to link it as a controller to the plc..
-Allan
| Posted: May 04 2007 at 13:48 | IP Logged
I believe that is not possible, but PH can be set up to poll devices and pick up on the change.
cmhardwick Senior Member
| Posted: May 04 2007 at 15:33 | IP Logged
it's not possible directly. Local Control sends out no commands so I don't think even the status change trigger would work, haven't tried it yet though. Like Tony says however, you can set the polling and it will pick up.
