MAWilsonPE Newbie
Posted: May 20 2010 at 10:29 | IP Logged
This should be easy but I am having trouble. I am trying to create a loop in a macro that executes a set number of times(3).
Set System TEMP3 1
Set System TEMP1 ph_regexdiff( "title=","AAAA","[TEMP1]",1,1)+"AAAA"
Set System TEMP2 left(ph_regex diff("title=","AAAA","[TEMP1]",1,1),1)
Set Global SITE77 "{SITE 77}"+"[TEMP2]"
Set System TEMP3 [TEMP3]+1
Jump if ([TEMP3]=3,999,-4)
I get the error: Syntax Error in Formula: if(2=3,999,-4)
Shouldn't 2=3 be FALSE and return a value of -4 for the Jump function?
Edited by MAWilsonPE - May 20 2010 at 10:35
sjvonstein Groupie
Posted: May 20 2010 at 10:54 | IP Logged
Here's how I do a repeat in one of my macros. If you'd like an export format, let me know
FORMULA ph_setglobal_a("COUNTDOWN",30)
LABEL INCREMENT
WAIT 1
FORMULA ph_addtoglobal("COUNTDOWN", - 1)
Goto Label if({COUNTDOWN}=0,"END","INCREMENT")
LABEL END
MACRO ALLOFF
FORMULA ph_setglobal_a("COUNTDOWN"," ")
MACRO TV OFF
Edited by sjvonstein - May 20 2010 at 10:55
MAWilsonPE Newbie
Posted: May 20 2010 at 10:58 | IP Logged
OK, I see. I can make that work.
I would still like to know why my "if" statement is wrong....
sjvonstein Groupie
Posted: May 20 2010 at 11:02 | IP Logged
It's possible the negative value is the problem. I've heard placing a space between the negative sign and value may be a fix. Try substituting the negative for a positive as a quick check.
Posted: May 20 2010 at 11:23 | IP Logged
I don’t have PH in front of me now but I would remove the comma from 3999.
sjvonstein Groupie
Posted: May 20 2010 at 11:24 | IP Logged
He's not intending the number 3 thousand nine hundred ninety nine. He's trying to return an if 3, then 999, else -4
MAWilsonPE Newbie
Hmmm,
I tried your suggestion and it is not incrementing. In the event log I can see that the global variable COUNTDOWN is changed from "blank" to 14, then 14 to "blank" again. It seems the FORMULA ph_addtoglobal("COUNTDOWN", - 1) is not working.
I tried changing the - 1 to -1 and even to 1 and it nevers adds it to COUNTDOWN.
sjvonstein Groupie
Posted: May 20 2010 at 11:28 | IP Logged
set all macro/formula executions to POST instead of immediate and try again.
Retain the space in - 1
Edited by sjvonstein - May 20 2010 at 11:29
MAWilsonPE Newbie
Posted: May 20 2010 at 11:37 | IP Logged
OK,
Using a combination of mine and yours I got it to work. It seems the JUMP function will not accept a negative value and that is my syntax error. So I am using two LABELS and the Goto Label to get the loop working. I am using the counter I set up, TEMP3 increments and the Goto Label jumps ot of the loop when TEMP3 hits the limit.
Thanks alot!
Posted: May 20 2010 at 11:38 | IP Logged
Damn, I better find new glasses…
sjvonstein Groupie
Posted: May 20 2010 at 11:43 | IP Logged
You're welcome.
lol@ BeachBum
MAWilsonPE Newbie
Posted: May 20 2010 at 11:48 | IP Logged
Maybe it is the IF statement that does not like to return a negative value than the JUMP. Goto Label works.
What happens if the formula is set to Post instead of Immediate?
sjvonstein Groupie
Posted: May 20 2010 at 12:05 | IP Logged
It's possible that the jump command isn't accepting a negative. Jump seems relatively obsolete with GoTo commands being so easy to use and are not dependent on changing line numbers. I'm not clear on the difference between post/immediate. I only know that changing most of my macros functions to "POST" has solved many problems.
Posted: May 20 2010 at 16:21 | IP Logged
OK, now that I have my glasses on try this for giggles.
If (ph_getvar_n(2,4) = 3, 999, -4)
Put a space before the dash.
MAWilsonPE Newbie
Posted: May 20 2010 at 18:11 | IP Logged
OK, it seems that the following:
If(ph_getvar_n(2,4)=3,999, -4)
is the same as If([TEMP4]=3,999, -4)
I am using TEMP3 so that should be:
If(ph_getvar_n(2,3)=3,999, -4)
Not sure if this has an advantage over If([TEMP3]=3,999, -4)
I like the Goto Label, it works. It may be that PH does not like JUMP = -4
Thanks for all your help, I got it working w/ Goto Label
Edited by MAWilsonPE - May 20 2010 at 18:13
Posted: May 20 2010 at 18:54 | IP Logged
Yep for some reason PH_GETVAR will always work and [xxxx] sometimes. I use GOTO and JUMP. Prefer GOTO in larger macros. Minus (-4) is working for me.
