        | jeremybe Newbie
          Hi -
           | Posted: May 09 2007 at 12:46 | IP Logged |   |
 |  I'm moving all of my home theatre equipment to my Family room and I have been working on controlling my Insteon lights from my MX3000 remote control - Originally I was going to utilize the IR X10 bridge, but I have decided I would like to keep everything X10 free (My Neighbors X10 signals keep jumping into my house!) - I purchase an Amplifed Xantech IR block and thought I would install a Xantech 490 IR receiver in my cabinet - The thought is I would connect the output of the the IR block to my USB-UIRT and have the USB-UIRT with Powerhome software control  the lights - My problem is that the Xantech block is located in my family room and my PC running Powerhome is locate across the house maybe 100 feet away - I would have no problem running a wire that distance, but can I have an emitter that far away?  How would I do this?
 Any help would be appreciated
        | Back to Top |     |
        | ginigma Senior Member
          Not sure where your USB-UIRT is located.  Can you move that to the Xantech block?  You can get USB cable extenders which run over Cat5 wire.  I'm using one that Dave recommended.
           | Posted: May 09 2007 at 16:24 | IP Logged |   |
        | nadler Super User
          I just started to use speakercraft ir which is similar to xantech.  I run an emitter from the amplified speakercraft block from the second floor to the basement and then one flight up to where my computer and USB-UIRT are located.  This is done over Cat 5e and altho I don't think it's quite 100 feet, it's pretty close.  Works well, with no false signals. I use my Harmony remote to control the lights in my bedroom.
           | Posted: May 10 2007 at 07:14 | IP Logged |   |
 |  You could always try it, just using 100 feet of wire, without running it through the walls yet.
        | Back to Top |     |
        | jeremybe Newbie
          I'm about 100 Ft away - I could use a USB extender I guess... Does it really work??? What brand did dave reccommend?
           | Posted: May 10 2007 at 11:48 | IP Logged |   |
        | Back to Top |     |
        | jeremybe Newbie
           | Posted: May 10 2007 at 11:50 | IP Logged |   |
| nadler wrote:
       | I just started to use speakercraft ir which is similar to xantech.  I run an emitter from the amplified speakercraft block from the second floor to the basement and then one flight up to where my computer and USB-UIRT are located.  This is done over Cat 5e and altho I don't think it's quite 100 feet, it's pretty close.  Works well, with no false signals. I use my Harmony remote to control the lights in my bedroom. You could always try it, just using 100 feet of wire, without running it through the walls yet.
 I'm a little confused, is the IR emitter spliced into the cat5???
        | Back to Top |     |
        | nadler Super User
          Exactly.  I cut the emitter wire in half and spliced the Cat5 in between. (I actually have it connected to cat5 plugs and it plugs into the wall, since each room has a Cat5 homerun to the basement.  But the same idea, just a little neater).
           | Posted: May 10 2007 at 12:44 | IP Logged |   |
        | Back to Top |     |
           | Posted: May 10 2007 at 15:44 | IP Logged |   |
| jeremybe wrote:
       | I'm about 100 Ft away - I could use a USB extender I guess... Does it really work??? What brand did dave reccommend? |  |  |  Here are links to 2 different threads with links to cat5 USB extenders.  I'm pretty sure I got the one from Cyberguys, and I got one with a 4-port hub.  I'm only using one port for now though.  Using more than one port requires a wall wart to power the hub (at the far end, not at the PC end).  I have no problems.
 Link 1
 Link 2
