nadler Super User
| Posted: February 06 2007 at 17:40 | IP Logged
Will the next PH beta include support for global cache or is it further away? I'm still looking at IR solutions and want to plan accordingly.
| Posted: February 06 2007 at 18:01 | IP Logged
Looks like it uses TCP sockets, so the existing socket support would work (if that helps you).
nadler Super User
| Posted: February 06 2007 at 18:17 | IP Logged
Dave had mentioned in several older threads that Global Cache support was coming (after Elk support). I don't know exactly what that means or if it will add more functionality than the existing socket support.
| Posted: February 07 2007 at 22:21 | IP Logged
Noel,
It's further away. I just got in contact with Global Cache and am in the midst of forming a partner alliance with them. They appear very interested in PowerHome adding support for they're product.
Hopefully I'll have a development unit soon and I'll be able to give a better estimate of timeframe.
cmhardwick Senior Member
| Posted: February 08 2007 at 08:44 | IP Logged
not to appear uninformed, but what's "global cache" ?
nadler Super User
| Posted: February 08 2007 at 09:10 | IP Logged
Cicero, you can find info on Global Cache at their website here.
As I understand it, it's hardware that allows you to send IR commands and RS232 commands and attach some sensors through your network. So if you have cat 5e or 6 hardwired to all your rooms (like I do) you would just plug this unit into your LAN and be able to control stereo, TV, drapes and whatever over the LAN.
It seems to me that it would eliminate a lot of wiring and consolidate a lot of separate systems (i.e. IR, RS232, sensors). For me it would eliminate USB-UIRT, Powermids, separate RS-232 wiring and extra RS-232 ports that I will eventually need on my computer.The prices seem pretty reasonable as well ($145 street for entry level).
With PH involved the possibilities seem almost endless.
Noel
| Posted: February 08 2007 at 15:26 | IP Logged
Sweet! i don't have cabling all through my house, and don't really need it, but it does sounds like a SWEET system!
Thanks Noel!
