        | fnkpet Newbie
          Hi - I am a new user and excited that I might have found something that can help my manage my insteon links. I purchased Homelinc in the fall and gave up on link management (it wasnt wroking too well)
           | Posted: May 09 2007 at 20:45 | IP Logged |   |
 FYI - I have about 90 insteon switches installed and use a front end from a company called Cinemar (Mainlobby) to control everything via touchcreens. I have extensive media servers (movies,music, pictures) and a whole lotta othrstuff going on re home conttrol.
 Anyway, 2 questions
 1) On the 'Insteon Explorer' interface the 'right' windowpane wherein I used the 'left and right' arrows to add responder and controller links has disapeared. I tried to drag the box border (by dragging it left) and I cant seem to get it back. How can I restore it?
 2) I am using SDM .235  Is that the correct version or is there a later one I should be under? (I got the .235 as part of my inetrface into mainlobby).
 Frank
        | Back to Top |     |
        | ginigma Senior Member
          Not sure about the Insteon Explorer window pane issue.  Maybe you need to "grab" the splitter bar at the top of the window.  Try to maximize your powerhome window also.
           | Posted: May 10 2007 at 15:51 | IP Logged |   |
 2) SDM 308 is the latest.
        | fnkpet Newbie
          OK. I got 308 and have installed.
           | Posted: May 10 2007 at 21:40 | IP Logged |   |
 I still cant figure the right pane thing
 See attached image.
 Can anyone help - I keep trying to grab a handle on the right but does not work. Tried maximizing screen etc....
 Frank
        | Back to Top |     |
          Um, can you post a link to a full resolution image?  I can't make out the problem from that pic.
           | Posted: May 11 2007 at 20:55 | IP Logged |   |
        | fnkpet Newbie
          Here
           | Posted: May 11 2007 at 22:06 | IP Logged |   |
 I hope this is better. Either way if you open insteon explorer on 'your side' you should see an area on the right that lists all the devices that then allows you to use the 'left' or 'right' arrows to assign them to the controller or responder areas.
 Mine has gone away.
 I DREW A BOX WHERE IT SHOULD BE labeled ' Missing'
 Thank you
        | Back to Top |     |
        | jpcurcio Senior Member
          fnkpet:
           | Posted: May 12 2007 at 02:33 | IP Logged |   |
 Where did you find SDK 308?  I've looked, and can't find it anywhere.  That probably means it's right in front of my face...
 -JPC
        | Back to Top |     |
        | fnkpet Newbie
          sdm 308 is here
           | Posted: May 12 2007 at 08:48 | IP Logged |   |
 http://www.codeplex.com/sdmsocketserver
        | Back to Top |     |
           | Posted: May 12 2007 at 22:56 | IP Logged |   |
| fnkpet wrote:
       | sdm 308 is here
 Got it... thanks!
 -JPC
        | Back to Top |     |
        | fnkpet Newbie
          Can anyone help with my missing window? Thanks
           | Posted: May 12 2007 at 23:40 | IP Logged |   |
        | Back to Top |     |
          See the vertical grey line/bar on the very edge of the right side?  That looks like the splitter bar.  See if you can grab that with the mouse and drag it to the left.  I wasn't able to get the splitter bar over that far on my system.
           | Posted: May 13 2007 at 21:33 | IP Logged |   |
 If that's not it, then Dave will have to chime in.  I took a look at the ini file to see if I could see something that looks like the Insteon window settings but nothing jumped out at me.  They may be stored in the database.
        | fnkpet Newbie
          Thank you.
           | Posted: May 13 2007 at 21:53 | IP Logged |   |
 Yes I see the grey bar and I have tried many times to grab it, click it, move it, etc. No luck..........
 Dave (or anyone) any help?
 Frank
        | Back to Top |     |
        | fnkpet Newbie
          OK - I was able to get the Device window back by un installing and re-installing the software.
           | Posted: May 16 2007 at 12:01 | IP Logged |   |
        | Back to Top |     |
        | dhoward Admin Group
          Arghhhh!!!!  I arrived too late.
           | Posted: May 19 2007 at 22:18 | IP Logged |   |
 Sorry Frank that you had to reinstall to fix this.  I dont know how it got so far to the right as PowerHome tries to prevent this from happening.  If it should happen again, the location of the splitter bars is stored in the pwrhome.ini file.  To fix this, just open the file in notepad and navigate to the [Insteon Explorer] section.   Next, locate the parameter "linksv1".  Set this parameter to a lower value such as 1000 and save the file (do all this with the Insteon Explorer currently closed).  Open the Insteon Explorer and the splitter bar should be visible and able to be resized appropriately.
 BTW, welcome to PowerHome and let me know if you encounter any other problems.
