        | MrGibbage Super User
          I have a big PLC group (about 20 devices... big to me anyway) that when I have PH turn on or off, PH kinda hangs for about 10 minutes.  PH is still running, but things get REEEEEAAAAAAALLLLLLLL Slow.  Eventually, it gets back to normal.  The SDM log shows this, over and over, while PH is in this hanging mode:
           | Posted: June 23 2007 at 16:02 | IP Logged |   |
 PLC:eventraw=03
 PLC:SRIR=send failed
 ui:srir=00 00 00 09 9C 72 45 12 05
 uifinished:srir=00 00 00 09 9C 72 45 12 05
 si:08 A7 75 09 9C 72 45 12 05
 ui:srir=00 00 00 09 56 50 45 12 05
 uifinished:srir=00 00 00 09 56 50 45 12 05
 PLC:eventraw=03
 PLC:eventraw=04
 PLC:receiveinsteonraw=04 09 9C 72 08 A7 75 65 12 05
 6/23/2007 3:58:43 PM:ackmsg=09 9C 72 08 A7 75 65 12 05
 PLC:eventraw=03
 si:08 A7 75 09 56 50 45 12 05
 PLC:eventraw=03
 PLC:eventraw=04
 PLC:receiveinsteonraw=04 09 56 50 08 A7 75 61 12 05
 6/23/2007 3:58:48 PM:ackmsg=09 56 50 08 A7 75 61 12 05
 What SRIR?  What do I do to fix it?  Reset PLC?  Is that what is causing PH to hang?
 Skip
        | Back to Top |     |
          By the way, all of the lights in the group turn on and off as expected, but this 10 minute pregnant pause is disturbing.
           | Posted: June 23 2007 at 16:13 | IP Logged |   |
 Skip
        | Back to Top |     |
        | dhoward Admin Group
          Skip,
           | Posted: June 23 2007 at 16:16 | IP Logged |   |
 Check out this post  http://www.power-home.com/forum/forum_posts.asp?TID=1318&PN= 1 and my response.  It's the same problem
          Awesome, Dave.  Thanks.
           | Posted: June 23 2007 at 17:07 | IP Logged |   |
 Skip
        | Back to Top |     |
