traviskleckner Senior Member
| Posted: December 20 2007 at 11:38 | IP Logged
Hello,
I've got a KPL linked to several loads (2 SwitchLincs, 2 LampLincs). There is nothing on the KPLs local load, but A button is linked to one of the LampLincs.
I'd like to have a scene that sets several lights, including turning off the LampLinc connected to the A button. I've got all the lights working, the problem is that I don't think I can turn off the A button with an "On" click of the F button. (I've tried linking the A button and setting it's value to 0, and I've tried the "Off" checkbox on the KPL Config.) Is there anyway around this?
Thanks in Advnace.
mimitche Newbie
| Posted: April 27 2008 at 19:30 | IP Logged
I'm having the exact same issue; any suggestions?
(I'm using PH for programming only; it is not connected full-time so it would have to be a non-PH controlled solution.)
Thanks in advance,
Mike
mimitche Newbie
| Posted: April 27 2008 at 20:06 | IP Logged
Nevermind, I figured it out.
6 button mode KPL- Button 6 was set as non-toggle off. In KPL config for button 6 I had "LED Off" checked for 1,3,4, and 5. By checking "LED Off" and "LED On" for both 1 and 6 as well it started working.
