        | UpstateMike Senior Member
          I linked a lamp to Powerlinc1 group 1 and am trying to control it with the command below. It doesn't work and I can't figure out what I did wrong...
           | Posted: June 22 2006 at 23:18 | IP Logged |   |
 ph_insteonrawgroup("POWERLINC1" 1, 17, 0)
 Any ideas?
        | Back to Top |     |
        | TonyNo Moderator Group
          I'm assuming that the forum stripped out the first comma.
           | Posted: June 23 2006 at 07:28 | IP Logged |   |
 Maybe these apply?
 Thread 1
 Thread 2
          Thread 2 was it! I was confusing the controller name with the Insteon name. Thanks!
           | Posted: June 23 2006 at 09:47 | IP Logged |   |
        | Back to Top |     |
          Is there any down side to using the same name for the Controller Name and the Insteon Device Name. What if I call them both PowerHome for simplicity?
           | Posted: June 23 2006 at 09:54 | IP Logged |   |
        | Back to Top |     |
        | dhoward Admin Group
          Mike,
           | Posted: June 23 2006 at 23:30 | IP Logged |   |
 Should be no problem...they are both within different primary keys so nothing database wise will keep you from doing it.
 It does get confusing sometimes with all the different ID's and when/where to use what.
