Posted: August 06 2012 at 19:31 | IP Logged
I am trying to use the system process shutdown trigger (fires upon PowerHome exit) to set the state of an Elk digital output at PowerHome exit.
From my log I can see that the trigger does fire as expected upon PH exit, except that the Elk output does not change as desired. I have tried "raw formula", "macro" and also "device control". My formula is: ph_setotherdigitalout("ELK",1,0,50,1) - and I did confirm that it does work (Elk output changes as desired).
It appears that the Elk controller gets disconnected before the shutdown trigger is fully completed. I even added a ph_delay(5000) into the raw formula of the trigger - still no luck.
Does anyone have other ideas to try? The Elk is the first controller I load (I know controller load order can be important).
Thanks in advance....
